Longer screw - by welding
Gäst
Inlägg av Gäst »
Does anybody have experience with electr. welding of a pellet-screw?
I want to make my förrad a bit larger and need to make the skruv longer (at the end, about 1 meter)
I made a test-welding - it seems to be strong enough.
I thought the skruvs are made of feather-steel, which can´t be welded.
It seems to be ordinary steel only (good for me).
Stugsittaren
Re: Longer screw - by welding
Inlägg av Stugsittaren »
libi skrev:Does anybody have experience with electr. welding of a pellet-screw?
I haven´t tried it but is but couldn´t it be wise to overlap the two screws 10cm or something like that? How did you do?
An alternative is to fit a pipe inside the screw say 50-100 cm long and secure the screws to the pipe.
Gäst
Inlägg av Gäst »
Yes, overlapping would not be a bad idea.
A copper-pipe inseide would make the diameter smaller. i think it could be reason for a pellet-jam at the beginning of the pipe...
I overlapped it 3 cm.
libi
Inlägg av libi »
Ok - i have my own experience now :arrow: it does only work as an emergency repair. The welded skruv makes a lot more noise then a single skruv.
And: The metal gets weakened also!
So if somebody must/wants to weld a flexskruv:
- overlap max 3 cm
- clean the outside of the welded part well by using a vinkelslip so that it doesnt skada the matningrör and motverkar the motor
- order snabb a new skruv
:wink:
