Hi Forum,
just wanted to tell about a idea, i had yesterday:
I wanted to monitor my bequem burner from the far.
Because i was not able to buy a interface to connect, i was building my own solution.
i used a siemens mobile phone and a talking thermometer.
when i ring this phone, it answer the call by itself and the talking thermometer (from Ebay, 7 €) says for example: "inside temperature sixty seven, outside temperature fifty five" Now i can measure 2 different temperatures!
so when i am away i can check if the heating is running...
the next step is to build a interface which is using DTMF-Tones (the tones you hear, when you touch any keys while calling someone) to switch the burner on or off and make a restart...
I will keep you updated!
Idea: Alarm for Bequem burner
1 inlägg
• Sida 1 av 1
Återgå till "Thermia / Ariterm"
Hoppa till
- INFO & REGLER
- ↳ LÄS DETTA FÖRST
- ALLMÄNT
- ↳ PELLETS - Eldning, Brännare, Pannor, Allmänt
- ↳ PELLETS - Förråd, Förvaring, Transport
- ↳ PELLETS - Pelletsleverantörer, Kvalitet, Priser
- ↳ PELLETSLEVERANTÖRER - Ris & ros
- ↳ PELLETS - Kaminer
- ↳ VED
- ↳ SOL - Solfångare
- ↳ SOL - Solceller
- ↳ VIND
- ↳ EL
- ↳ LUFT / BERG / SJÖ / JORD
- SPECIALOMRÅDEN
- ↳ ACKUMULATORTANK / KOPPLINGAR
- ↳ GOLVVÄRME
- ↳ POOL
- ↳ PELLETSPRESSNING
- ↳ NY TEKNIK
- LOGGNING
- ↳ MANUELLA LOGGAR
- ↳ AUTOMATISKA LOGGAR
- ↳ LOGGNINGSTEKNIK
- DIVERSE
- ↳ ÖVRIGT
- ↳ FORUMET - Feedback / förslag
- ↳ MARKNADSFÖRING & ERBJUDANDEN
- ↳ Köpes
- ↳ Säljes / Bytes / Skänkes
- BILDER
- ↳ PANNRUMSBILDER
- FABRIKAT
- ↳ Biona
- ↳ Bionordic
- ↳ CTC / Bentone
- ↳ EcoTec
- ↳ Eurofire/Baxi
- ↳ Nibe/Iwabo
- ↳ Janfire
- ↳ KMP
- ↳ Pellx (Gordic)
- ↳ Roslagsbrännaren
- ↳ Thermia / Ariterm
- ↳ Tunab / Blueflame / Jetflame (EJ JANFIRE JET!)
- ↳ Ulma
- ↳ Värmebaronen
- ↳ Övriga fabrikat
