Optosensor
Optosensor
This morning i found my bequem50 with the message "Alarm Optosensor"
The manual says either dust on the sensor or too much sawdust with this pellets, so the burner cannot keep the pellets glowing.
Anyone the same problem?
The problem can also appear when you have problem with the pellets supply. If there is air in the external screw and the burner askas for pellets and the screw runs but ther is only a airpocket.
This causes the burner to run out of pellets and the glow goes out.
1 1/2 plan 1954 98m2 plankkåk med 4" sågspån på vinden
- Stugsittaren
Are there other optosensors? I think it uses an IR-sensor to control the pelletslevel before the "matarskruv". Could dust on this sensor create a similar alarmcode? Is the IR-sensor an optical sensor?
- Stugsittaren
