Icecap skrev:Now I don't follow...
I do get the idea of having a day-rythm but that will affect the whole house as it's the shunt that's regulated.
That is exact what i want (and what i do currently manual every evening and morning).
Icecap skrev:
But You talk about roomsensor... It's not possible (afaik) to regulate only one room that way.
The delivered and installed room sensor (in the living room, where the most constant temperature is needed) controls the SPS of the Ulma > pump and mixer, in fact the SPS regulates the heating flow (Vorlauf) and the pump pressure. The heating flow and the pump pressure should be lowered in the night. The individual temperature in the rooms are controlled in the rooms by the radiator thermostats.
Icecap skrev:
But in my point of view thats the wrong way round to go, the programming should be done in the furnace, setting the target temperature. The complexity would be about the same and the result would be far better and stable.
Sure that feature is not available already?
Unfortunately there exist no such a functionality. So there is not an easy solution... What i found are programmable radiator thermostats. But they are expensive
Anyway, i will research a bit longer. Thank you for your ideas.
Frank
Ulma 2000 PK, heating 120 sqm space from 1901...
