code for level3 "SEKVENS"
Gäst
Inlägg av Gäst »
Anyone knows how to access this level?
Patrik
Inlägg av Patrik »
try to hold in right+left key at the same time in 5 seconds.
after you have entered the service level push right untill the "EFFEKT 0" appears
Then press upp key "EFFEKT 3" and wait untill the number stops flashing.
Now you are in.....just press right key for the different variabels.
per pellet
Inlägg av per pellet »
I'm a bit confused. Libi was asking for the code to the SEKVENS menu, but you are giving him a code (3) for the EFFEKT menu.
I thought the code for the EFFEKT menu is 5. Do you mean that the code for the SEKVENS menu is 3?
(I would also be interested to have a look at the SEKVENS menu.)
Biomatic 20+, 800 liter veckoförråd, Thermomatic Combi shuntstyrning.
Gäst
Inlägg av Gäst »
hmmmm, somehow it doesn´t work for me.
the service level with code 5 is no problem, but i am not able to access the sekvens-menu...
Patrik
Inlägg av Patrik »
Ups i thougt the effekt 3 was the sekvens meny :oops:
Gäst
Inlägg av Gäst »
I don´t believe nobody knows the Code :wink:
Gäst
Inlägg av Gäst »
hi libi,
i can give you the answer to your question:
the code is "65"
just enter "service menu", then go to sekvens, then "arrow up" to 65, wait until blinking stops and you can enter the menu with "arrow right"
have a nice day,
libi
:wink: :lol: 8) :twisted:
