Vilket "monster"
Vilket "monster"
Var på Energicentrum i Jönköping (bra utställning)
Fick syn på Fröling FHGTurbo 3000..... www.froeling.com
Har någon hört priser ?
//P
//P
Vedolux37 + Stocksbrotank 4-sling 750L + tomtank 750L Exoheat 1858 2x24 rör,
Priser...
In Österrike they take 8800 EUR for the 30kW model incl 2000l Acktank.
The burning chamber lies directly under the filling chamber.
Burning very small wood pieces or wood chips may cause problems
The burning chamber is a specially designed chamotte (fire-concrete)-part -> can only be changed with original part, not with cheap standard size pieces.
This chamber may get damaged when burning wood with nails or while cleaning the oven. You should only clean the burning chamber with a vacuum cleaner.
Own door for firing up (the small one) in the middle
regulated fan
![Bild](http://www.mutscher-heizungsbau.de/img/froeling_heizung_holz.jpg)
regulated fan
