Video of thermia bequem
Hi,
for those whoe are interested in the function of a bequem burner i added a video to my website
http://de.geocities.com/hohlaender/pellets/pellets.htm
the link is at the bottom below the "update" logo "Download hier"
libi
libi
Thank you.. That was kind of interesting. Your Bequem seems to run so much faster and easier when "pushing" pellets into the burning area..... My is so slow.. even running on the "high" mode its much slower than yours, and seems to have such a hard time when pushing pellets.. There are no sounds that I could notice, my burner sqeeks and sounds with a annoying high frequent sound..
Biomatic 20+
Thats because he has a Bequem 50Älghår skrev:Thank you.. That was kind of interesting. Your Bequem seems to run so much faster and easier when "pushing" pellets into the burning area..... My is so slow.. even running on the "high" mode its much slower than yours, and seems to have such a hard time when pushing pellets.. There are no sounds that I could notice, my burner sqeeks and sounds with a annoying high frequent sound..
Thermia Biomatic 20+ med 200kg förråd.
That I know. But I am still faschinated about the differnce.. here are my contribution .. a pellets movie directly from my "pannrum"..patrick skrev: Thats because he has a Bequem 50
This is how my Bequem sounds and looks..
http://hem.passagen.se/anga/pellets.mpg (18 mb)
Biomatic 20+
Vår låter inte hälften så mycket ens, Tillverknings nummer 4932Älghår skrev:That I know. But I am still faschinated about the differnce.. here are my contribution .. a pellets movie directly from my "pannrum"..patrick skrev: Thats because he has a Bequem 50
EDIT: Kollade filmen igen, du måste ju ringa thermia så dom får fixa det, låter ju fruktansvärt.
Såg att du har vänstra knappen på pannan intryckt oxå, den med vattenkranen på, den kan du stänga av, pannan kör den pumpen automatiskt vid behov.
- Lärjunge!
Jag har ju i och försig ingen brännare hos mig ännu. Men om det kommer att låta på det viset får jag nog se mig om efter en annan typ av uppvärmning... Låter ju värre än en mekanisk verkstad... Tänk om grannarna skulle börja klaga på oväsen i min källare mitt i nattenÄlghår skrev:This is how my Bequem sounds and looks..
Senast redigerad av johansjostrand den sön 23 okt, 2005 11:36, redigerad totalt 1 gånger.
De är nog kameran som fångar upp o förstärker ljudet en hel del..johansjostrand skrev:Jag har ju i och försig ingen brännare hos mig ännu. Men om det kommer att låta på det viset får jag nog se mig om efter en annan typ av uppvärmning... En hel mekanisk verkstad låter ju inte hälften så mycket... Tänk om grannarna skulle börja klaga på oväsen i min källare mitt i natten
Du skulle få höra en biona då kvarnen går..
André skrev:De är nog kameran som fångar upp o förstärker ljudet en hel del..johansjostrand skrev:Jag har ju i och försig ingen brännare hos mig ännu. Men om det kommer att låta på det viset får jag nog se mig om efter en annan typ av uppvärmning... En hel mekanisk verkstad låter ju inte hälften så mycket... Tänk om grannarna skulle börja klaga på oväsen i min källare mitt i natten
Visst kan säkert kameran förvränga, alt. förstärka ljudet en del, men jag tycker inte att jag skall kunna stå på våningen över källaren och höra när skruven matar pellets
Biomatic 20+
Hehe visst är det kameran som förstärker/förvränger ljudet. Alla dessa ljud men f*n jag sitter och skrattar så högt som det verkar vara på filmen är det ju inte. I slutet låter det precis som du säger som en hel verkstad. Faktum är att jag knappt hör vår panna i rummet sidan om pannrummet trots att dörrarna är öppna. Jag håller med om att den är tystare än oljebrännaren vi hade innan.
Är man sjuk i skallen om man sitter och tittar på sådana här filmer med ett stort leende på läpparna?
Älghår: Om det är så att du hör pannan på våningen ovaför tror jag du bör ta dit nån som kollar på det.
Då: 30 000:-/år med olja
Nu: 15 000:-/år med pellets
4 kg/m² & månad
Huset byggt 1947
4 kg/m² & månad
Huset byggt 1947
Allt beror ju på hur mkt man vrider upp volymen på högtalarna .. Men de facto är att ljudet som ni hör är inte annorlunda än "i verkligheten". Det knirrar och gnisslar hela tiden.. Om ni lyssnar exakt vid 1.35-1.45), hör ni ett gnisslande ljud, det är värst.. Det kan gnissla (på filmen ca 2 sek) men ibland upp till en minut.. Och det skär genom väggar och golvwertok skrev:Hehe visst är det kameran som förstärker/förvränger ljudet. Alla dessa ljud men f*n jag sitter och skrattar så högt som det verkar vara på filmen är det ju inte. I slutet låter det precis som du säger som en hel verkstad. Faktum är att jag knappt hör vår panna i rummet sidan om pannrummet trots att dörrarna är öppna. Jag håller med om att den är tystare än oljebrännaren vi hade innan.
Ljudet i slutet är ju fläkten som blåser på pelletsen under "hög"-läge, vilket säkert är korrekt..
Och ja.. visst är man lite sjuk om man älskar pelletsfilmer
Biomatic 20+
- Stugsittaren
Har just sett filmen. Har du prövat att spruta lite 556 eller liknande oljeblandning för att få ner ljudet?
