Can somebody pls. explain what happens if i rise the ventilator-speed (flakt) in the service menu.
Do the pellets burn better?
Is the efficiency of the boiler worse?
does the Fluegas temp rise?
There is a link to a swedish document in the forum http://www.swd.se/pellets/forbrlara.htm., but i do not understand enough swedish...
The reason for my question is, that i want to keep the temperature of the burner-bowl lower after that happened http://www.pellets.info/viewtopic.php?t=2470
What effekt if i rise the "flakt" ventilator
If you ad more air (fläkt) then the Fluegas temp will rise.
If the flame in the burner cup is a bit Red = to little air (use more fan/fläkt)
if the flame in the burner cup is bit White = to much air!
The flame shuld looking like the piture http://www.swd.se/pellets/flamma.gif
That is what it says about the air & temp in
Hope this helps you a bit..
