matning oljud
libi
matning oljud
Inlägg av libi »
a friend of me has a problem:
His extern matning screw (5m long, 1x 45° bow) -större motor-
is very loud since a few days.
The noise comes from the screw inside the matningrör. Every few seconds it turns very fast for a part of a second. It seems like it goes first very hard and then the screw relaxes very quick. And that makes that cruel noise.
What would you suggest? Tighten the screw? Or loosen the screw? Or what else?
Tack
Ideal Standard 1965
Bequem 50
12 t Storage
9m screw
450 m2
libi
Inlägg av libi »
The problem is solved!
The screw broke last night:-(
Ideal Standard 1965
Bequem 50
12 t Storage
9m screw
450 m2
libi
Inlägg av libi »
Just wanted to let you know:
The central pipe inside the skrew unter the matning holes has moved away from it´s position ( mounting-error ). So too much pellets went through the bows and blocked the skrew (compression).
A new skrew and a correctly mounted copper pipe made the matning system go quiet and soft now!
Ideal Standard 1965
Bequem 50
12 t Storage
9m screw
450 m2
