...does anybody know something about this error-message?
It´s not described in the manual. And it´s not "ALARM MAX TERMOSTAT".
I read about this in a german forum and wonder what this error message might mean?!
It appeared after the motor of the intern screw died after a blockade - reason
unknown
Thomas
message: ALARM TEMPERATUR PANNA
Ideal Standard 1965
Bequem 50
12 t Storage
9m screw
450 m2
Bequem 50
12 t Storage
9m screw
450 m2
Off the top of my head i would believe that an electronic thermostat has been trippet before the physical overheat protection. I have no knowledge of the furness Your'e having but that would be my guess:
Heat safety chain:
1: Electronic sensing and alarm ("ALARM TEMPERATUR PANNA")
2: Physical thermostat cutting power. ("ALARM MAX TERMOSTAT")
In that order an You've had the first step.
But as i wrote: i don't know, it's just a guess.
Heat safety chain:
It happend to one i know that the whell that looks like a ninja star gaot caught on one of the pins and the engine stopped due to this stop an the alarm was ALARM MAX TEMP PANNA.
The exponation he got that the bequem doesent got any wrong message for this so the bequeem must alarm for something and this is the closes wrong message he gots in his software.
1 1/2 plan 1954 98m2 plankkåk med 4" sågspån på vinden
